Results 1 to 7 of 7
Thread: Woodford Model 17 Faucet Leaking
    Default Woodford Model 17 Faucet Leaking
    I have a Woodford Model 17 faucet and is leaking when I hook a hose to it. It inside the wall therefore, I am not sure why's or where it's leaking. Can you tell me what or why it'd I am seeing this leak?
    Thanks,
    Albert
    Apr 2005
    Hose bibb is defective. Somewhere at some point a hose was left on it during the winter/freezing months possibly and water could not escape the faucet, thus the reason it froze and broke.
    When you take that faucet out, 2-3" behind that brass spigot you will find a belly in the copper where it bulged out and broke.
    Replacement is the only way to go; the only prevention is having nothing attached to that faucet so it can drain. Otherwise it loses its protective features altogether.
    Plumber Cass's Avatar
    Nov 2005
    Quote Originally Posted by RUGGED
    Woodford makes this now
    https://www.buywcm.com/egl/products/group.asp?pgn=19
    First of all thanks for your quick replied. I am a rookie at this and faucet is mounted onto a brick wall, do I have to remove the brick in order to fix or replace the the damaged component?
    Again, Thanks for your explanation.
    Nov 2005
    No.
    You need to get to it in the basement or crawlspace.
    If you are on a slab you will have to cut the wall where it is located in the house in order to replace it.
    Do you know how to sweat copper?
    Once again Thanks for your replied. No, I don't know how to sweat copper.
    Quote Originally Posted by Cass
    No.
    Nov 2005
    Central Florida
    Default What better time to learn?
    Quote Originally Posted by adl9413
    All you need is a torch, pipe & fitting cleaning brushes, flux, solder, a supportive spouse, and a fire extinguisher, and you're good to go. OTOH, if this is likely to be the only joint you'll sweat in your life, call a plumber. If you promise not to help, he may let you watch, and if he's really a good guy he'll give you a running commentary on what he's doing, which will probably make you happy you called him.
