This weekend I plumbed an outdoor shower that will be drained seasonally. I ran 1/2 inch pex out to the shower area and built a shower 'manifold' out of copper.
The manifold - the hot and cold lines run up seperatley to simple gate valves. After the lines pass through the gate valves they run to a copper t and then up to the shower head.
I tested the hot and was pleased with no leaks and ok water preassure. I then connected the cold and tested the shower. To my surprise, there was no water preassure at the shower head. The hot water ran up the cold water line when both valves were open.
Is there a preassure balancer or a water backflow preventer that I can install to prevent this? Or will a standard mixing valve that comes along with a shower assembly prevent the higher preassure hot moving up the cold water line?
I wanted to stay away from the single dial shower assembly and use a simpler outdoor friendly hot and cold spigot.
