Results 1 to 10 of 10
Thread: Tired of Mixet shower handles
    Default Tired of Mixet shower handles
    I'd like to replace 2 showers with Mixet with a different brand. I'm told that these pieces must be replaced with same brand due to match with valve.
    True? Or are there other brands to choose from that can fit on these valves too?
    Am trying to avoid going through tile and dry wall for repair if possible. Thanks!
    Feb 2005
    Talking they are junk
    no, you are screwed....they are a pain
    you will have to cut them out from behind
    and preferrably install DELTA 1700
    pressure balanced faucets....
    Default valves
    Once you access the brass part in the wall, you can install any valve you want to. But I also prefer the Delta 1700 series.
    Plumber jimbo's Avatar
    You cannot REPAIR your shower with anything but Mixet parts. Faucet parts are not generic at all......must match brand and model. The best you could to is possibly find a brushed nickel escutcheon. Mixet parts are getting scarce.
    If you can get access inside the wall, from the front OR from the backside, then you can install any new shower valve you wish.
    Mixet
    Default mixet
    Jimbo. One company makes a Moen style cartridge for the Mixet which eliminates the crossover problem common with Mixets.
    Thanks hj. I jave heard of that anit-crossover cartridge, but have not used it. My point was also that choices of upgrading the "look" are limited to the brand. Does that aftermarket cartridge require still the Mixet handles, or doe it use Moen handles and trim. If the latter is the case, that would open up a few more opportunities as far as handle and trim styles and colors.
    Default mixet
    I haven't used any either, but I had many apartment complexes in the early 70's that had serious crossover problems to the point where the apartments at the end of the runs could not get any hot water at all. These would have fixed them. They use the Mixet body, so you have to use Mixet trim.
    DID YOU EVER FIND OUT OF YOU CAN USE OTHER NON MIXET TRIM AFTERWARD?
    schneider120@hotmail.com
    Default mixet
    The body requires the mixet trim plate, and the replacement cartridge requires the Mixet shut off knob to control both flow and temperature just like a Moen valve. Nomix Inc. repair cartridges that fit Mixet brand valves
    Notice the price on the NOMIX. You have to be dedicated to stay with Mixet/
  1. MIXET shower valves
    By Landlord in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2013, 10:42 PM
  2. mixet shower valve
    By ldf in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2008, 03:28 PM
  3. Mixet Shower Faucet
    By smokeybear in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 05:11 AM
  4. Old Mixet shower valve
    By David here in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2007, 11:00 PM
  5. Mixet shower cartridge
    By AnotherHomeOwner in forum Shower & bathtub Forum & Blog
    Last Post: 07-05-2006, 08:28 AM
