Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Bad flush w/no vent
    Previous member
    Jul 2005
    Riverview, Fl.
    Default Bad flush w/no vent
    I brought this problem up here before. Since every one says a toilet won't work without a vent. I will agree. However the toilet does flush sometimes quite well. The floor the toilet sits on is 8" of concrete. I've been there with a jackhammer in the past. There is no way to install a vent without tearing up a lot of this floor which I am unwilling to do. I don't know why this unit was installed this way, but it's what I have to deal with.
    I managed to find the 3" pipe leading to the tank about 3 feet from an outside wall 10 feet from the stool. I cut a 1-1/2" round hole in the top and inserted a short piece of PVC pipe into it. This provides the only vent in the entire line.
    My question: Which low flow toilet would work the best to not cure but possibly improve this situation. I don't know what brand toilet I have now but it is 3+ gallon flush.
    I am going to order one from Terry, but I want to get the best option possible.
    Thanks in advance.
    bob...
    Plumber Cass's Avatar
    I like the Caromas, they have a 4" trapway may help with the no vent problem, but what ever you get I would get a dual flush.
    Many of the people who I have sold Caromas to tell me that the 1/2 flush works reguardless for both.
    You may find that a 1/2 flush will work all the time or worst case you do 2, 1/2 flushes.
    Previous member
    Jul 2005
    Riverview, Fl.
    Is this a Toto brand? Since I am a well guy, I'm not real up on toilets (thank God).
    This whole installation is a botched job. But I bought the house this way. This is the pool house that is two story, has a bathroom on the lower level where this stool is. The bathroom used to be much smaller until we took out a closet and added a shower which I plumbed into the tank with a different pipe to the tank. It works great. The toilet is the only problem and is only used during partys etc. And I don't have to tell you how that goes with this toilet. They still haven't built a plunger that will do it with just one push.
    bob...
    Default Try venting from the top, with a rear discharge bowl
    Bob
    Try this: get a rear discharge toilet, and then place it slightly farther forward than the existing one, and then your NEW vent can come down from above.
    Rear discharge can be either a wall-mount or a floor-mount (rarer animals, these). A wall-mount toilet can take as little as 26 inches total space front to back including the tank. And you can even position the toilet differently, like on a 45 degree angle, or 90 degrees. In case you want to change the layout too.
    David
    Caroma is a brand. They are made in Australia.
    Google the name Caroma Tasman 270 or Caroma Caravelle 270.
    Tasman and Caravelle are about the same but the Tasman has a plastic tank and is less $$$$. Caravelle has a ceramic tank. Both have a 4" trapway but small water spot.
    I think Terry carrys them also.
    Previous member
    Jul 2005
    Riverview, Fl.
    This sounds good guys. So how do I work the vent? I'm not with you on that part. I wouldn't mind getting into the wall behind it if necessary to install one. (Well I would mind, but if that is what it takes, I'll do it)
    I'll go have a look at the tank.
    bob...
    Previous member
    Jul 2005
    Riverview, Fl.
    Now for the other kink. The bathroom fixtures are all black. Sink, toilet, towel racks, paper hanger etc. What do you think the little woman is going to say when I install a bisquit colored toilet? They don't have them in Black. Just my luck. Any other suggestions are greatly appreciated.
    bob...
    Default Mick Jagger said to paint it black
    Bob
    Geberit has three different in-wall carrier systems (almost identical) that carry wall-hung toilet bowls made by a dozen other manufacturers.
    You'll find one black. Or paint it black.
    The Tessera model bowl is Geberit's own, and it must be located directly above the hole in the floor. The other carrier models can be situated wherever you want to, and you direct the drain to the hole in the floor using bends / elbows.
    You can also get a floor toilet with a rear discharge, made by various US manufacturers. Some condo buildings have only this type of toilet, since the drains were designed to be in the "common property" space inside extra large wall cavities.
    Hope this helps.
    David
    Previous member
    Jul 2005
    Riverview, Fl.
    David,
    What would be involved in making a wall able to hold the toilet and a say 300 lb. guest?
    bob...
    Toillets will siphon without the vent I'm told.
    Since you added one ten feet downline, it may be vented anyway.
    The vents are normally done within six feet.
    Since the toilet works some of the time well, and somtimes not, I would think that a repair of the toilet, or a new one would do just fine.
    There are many toilets that would work well for you.
    Previous member
    Jul 2005
    Riverview, Fl.
    Can you recommend one for me. I have seen so many in your store, that I don't know where to start. Knowing my problem and the way this thing has been acting, can you recommend one that might be the best for the job?
    bob...
    You can't go wrong with the Toto Drake.
    and a few others, Caroma, Aquia, Ultramax, Dalton, Gerber Ultraflush
    Default Unclear to start with
    Quote Originally Posted by speedbump
    ...The bathroom used to be much smaller until we took out a closet and added a shower which I plumbed into the tank with a different pipe to the tank. It works great. The toilet is the only problem...
    Bob,
    Tell me what tank you mean.
    Where is the closest vent to the toilet? Downstream, I presume. How far? What else is connected? Where, how? Please.
    David
    Default toilets
    Toilets will flush without a vent, and sometimes better without one, but the air in the pipe has to have some way to escape as the water tries to displace it. Without any air outlet, and with a closed system such as a septic tank, most 1.6gpf toilets cannot create the pressure needed to overcome the backpressure. If the hole in the pipe allows the toilet to flush properly, and it should if the only problem is the lack of a vent, then a riser pipe anywhere in the system is all you need. Otherwise, you do not have a vent problem and have to locate the real cause of the non-flushing.
    Previous member
    Jul 2005
    Riverview, Fl.
    I'm not sure what you mean by what tank David. The vent is downstream about ten feet from the toilet and 20 feet before the septic tank. It is a hole in a 3" pipe with a piece of 1-1/2" pipe sticking up above ground. No restrictions there. I just checked it the other day. The 3" pipe was nearly empty when I checked. I really think the main problem is this old low flow toilet. I think it was bought around the time they became mandatory and hadn't been improved on yet.
    My vent should do what you suggested HJ, so I'm going to order a Toto and check for any restrictions when I remove the old one.
    I'll let you all know how it goes. I'm going to go spend money in Terry's store.
    bob...
