cat3
- Messages
- 5
- Reaction score
- 0
- Points
- 0
Hello,
I'm thinking about moving the washer hook up/drain in my laundry room and have questions about the abs drain stack up.
There is a 2" abs pipe coming up thru the slab with 3 tee fittings installed with no more then a 1/4 inch spacing between the fittings.
In order to relocate the washer drain, I would need to replace a couple of the fittings but they are installed so close to each other that there isn't enough "virgin" pipe and I would have to re-glue one side of one fitting. Is this possible to do or am I setting myself up for a drain line leak/failure?
