Hello,
I'm getting ready to remodel a laundry room and am planning to move the washer from its present position. Here's a brief description:
East wall: 2" waste pipe w/ 1.5" vent approximately 2 ft from the north wall (this is the existing sink and washer hookup).
I would like to install the washer on the north wall approximately 5 feet from the east wall. in the northeast corner of the room I would like to install a 20x24 laundry tub.
Here are the questions:
1) Can I install the 2" stand pipe for the washer and the sink drain on the same 2" line inside the wall? I would need to make a 90 degree turn from the north wall to the east wall and then tie into the existing stack.
2) Would this 7' length of drain line be OK if all fixtures are wet vented through the existing 1.5" vent in the east wall.
3) Would I be better off with something like this:
..............VVVVVVVVVVVVVVVVVVVV turn 90 deg and then 2' to 1.5" vent
washer.....V...............V
D.............V...............V
Ptrap.DDDDDDDDDDD.sink.DDDDDD. turn 90 deg and then 2' to stack
D = drain pipe
V = vent pipe
(ignore the dots... they were needed to make everything line up)
Obviously the horizontal run of vent would be above 42" and all lines would slope appropriately. I would maintain the vertical connection between the stack and vent line
I guessing that the drawing above is the way to go...
Thanks for any insight!
-Andrew
D = drain pipe
V = vent pipe
-Andrew
