For the past few months I've been replacing my Moen cartridge in my bath tub. Every couple of months, not only would the be a small leak, but I couldn't turn off the water.This is one of those push and pull type of handles (counter clockwise is hot and clockwise is cold). I couln't push the handle back in to turn the water off unless I turned it off at the main, then I could press the handle in and turn it off. I've replaced the cartridge 5 times.
Today I decided to do a thorough investigation. I noticed that on the back part of the cartridge there were some wear marks as if if something was rubbing against it. In the past I pulled the cartridge and flushed the water hoping something would dislodge. I tried it again today and low and behold I noticed a screw with its pointy end sticking out on the left side (hot water side?) of the pipe when I pulled out the cartridge I guess the head was too big to fit through the pipe hole. I believe this is rubbing agains the cartridge and wearing it downa and preventing me from turning the water off. If I pull the backplate off, I can see a cross pattern of the pipe. I believe the top goes to the shower, the left is where the hot water comes in, the right is where cold water comes in and the bottom is where the water comes down into the faucet? So I tried pulling it out with a big pair of tweezers to no avail. In fact, the screw went back in. I flushed the water again and the pointy end of the screw was visible again. I tried again and the screw went back in the pipe. I flushed one last time and the screw never came back up again. I know it's in the pipe and will eventually point out again and cause damage to the cartridge.
I have a one piece full size plastic tub (the kind that has the walls built in with the tub. I was wondering if there was something I could do before I called a plumber. I'd like to suck it out with a vacuum cleaner or something from downstairs, but I don't think it's feasible. I was hoping to get suggestions from board memebers. If I did call a plumber, do you think he would have to rip the whole tub out? My only concern is that if he did come out, what if the screw went back down and came back up after he left? This might get costly and was hoping to try something before I went the plumber route. Any input is appreciated. Thank you.
