Dexnavigator
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I am installing a jetted tub in place of a fiberglass tub-shower combination unit that cracked in my 1996 home. I have not been able to locate a tub that has the exact wall to drain clearance (from the back of my RHD alcove) as the old tub, and therefore need to move the drain and supply lines (pvc). No problem with the (now exposed) supply lines, but does anyone have a suggestion how to move the drain over only 3/4 inch? The tub is on the second floor with no exposure from underneath. Even if I open the wall up on the first floor, a 45 elbow will move me over too far?!? Not real thrilled with the prospect of a rubber tube clamped to the pipe, I want to live here a long time and do not trust that arrangement long term.
There is a pan built of flashing around the drain pipe, so I am unsure exactly what is under/around my drain. It appears to be solid wood from the joists. One additional question, is the seat between the tub/overflow connector and the floor drain simply a compression fitting (i.e. can I pull straight up to disconnect or could I break something)?
