Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Water Flow by the Well cover
  1. #16
    OK, Can you tell me where the prime plug is.
    I have a Goulds j7 pump
    deep well, two pipes,1 1/4" on top and 1 " on bottom.
    I see two hex nuts in back. one near top center.
    The other bottom left, and a little bigger.
    I am going to try the one near the top, since this is where I want the air out.
    Wish me luck... thanks again
  2. #17
    Previous member
    Jul 2005
    Riverview, Fl.
    I am not real familiar with Goulds model numbers. Most pumps either have a prime plug of 3/4" or 1" on top of the pump or the installer is expected to put a priming tee in the only outlet to make priming possible.
    I have seen many DIY installations that I have no idea how they primed the pump, since they used an elbow instead of a tee with a plug in the top.
    The important thing is, to get the pump full of water. Then it should prime.
    bob...
  3. #18
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    The Goulds J7 has a 1" outlet on the top. You need that tee with a plug in the top that should have been installed with the pump.
  4. #19
    Well , I went to Lowes and got the tee valve and adapter to prime. Instead I rear ended someone in the parking lot. My day went from bad to worse. There was plenty of water, so I called the well guys. They pulled up the well and there was a tiny screw head stuck in the venturi of the foot valve. All is well now. I have water ,,,, Thanks for all the input. I learned a lot.
