Hello Folks,
Got a Yorkville but it has to head back because of a wee curing crack in the water intake port. I called A/S and they said it's better to get a replacement. Ok, can happen. Anyway, since I wanted to get done with the wall I placed it for a "sanity check". This was quite a surprise.
It's a back discharge commode and the rear bolts would not fit. I had them exactly six point zero inches on center as per spec. Only significant bending of the bolts would have made them go in. So, I measured and found that the holes in the toilet were less than 5-3/4" apart and also smaller than the usual 1/2" wide by 3/4" high. Same for the bottom bolts. Thank God I haven't drilled the tiles yet. The waste outlet was a bit high (I had leveled the floor tiles to exactly 4" as per spec). Also, the toilet rocked a lot, sideways and back. I took great care to have the tile floor perfectly flat, like usual in a bathroom.
Questions:
1. How much maximum wiggle should a toilet exhibit on a perfectly flat floor?
2. Spec sheet distances for the screws: Do they mean anything these days?
Quite frankly, for $280 plus tax (sans tank, of course, which is another $200) I had expected more. All the cheaper toilets I ever placed hardly needed any shims but that was a long time ago and not in the US.
Regards, Joerg.
Questions:
Regards, Joerg.
