You may have been looking at a Toto valve. For ease and service, longevity, and parts availability, you cannot beat the Sloan/Zurn valves. Zurn being a Sloan knockoff.
OK, this is my first post here. I want to state right up front that I'm not a plumber or a contractor...
I prefer manual flushometers over tank toilets. I have two issues I need to resolve before making a final purchase decision:
1.) How to determine which flushometer hardware is compatible with which toilet bowl.
2.) Finding a flushometer that I'm satisfied with, from a design perspective.
Regarding the second issue- So far, I'm most inclined to either the Sloan Crown II, or the Sloan GEM... however, I've seen flushometers in some upscale hotel/restaurant bathrooms that have even cleaner lines/less detail than these two models. Though I'm detail oriented enough that I noticed, and took note of them, I wasn't in the market for one at the time, so I didn't get the brand. Now that I'm in the market, I'm not finding these, shall I call them "designer flushometers".
My suspicion is that they are European manufactured, and probably have some other name rather than "flushometer". Does anyone know what "flushometer" is in Italian?
Thank you for any assistance.
I've looked at Toto on their website at:
http://www.totousa.com
They do have a selection of flushometers under their commercial products, but they're not really what I'm looking for.
Once I stopped searching under "flushometer" and changed my search string to "flush valve", I've found some other manufacturers. Right now I'm limiting my advanced google search to seach by a specific domain sufix (".it") to seach only in Italy. That yielded the Italian plumbing manufacturer named Bocchi:
http://www.bocchi.it
I have not found what I'm looking for there yet, but I think I'm on the right track. If Bocchi doesn't offer what I want, then I'll also look for German companies.
Thank you for your help, and I'll report back on whether I've had success.
cheers,
Chris
Here are a couple of simple ones-
TEMPO® 300 Push button flush valve
TEMPO® 370 Lever operated flush valve
That 370 model with the lever sticking straight up is really great (my wife may accuse it of looking too phallic... but hey, it is a toilet, after all)
Question fcor you, HJ (or anybody who would know)-
Can you tell if these would work with standard US plumbing?
thanks for any help
I would like to know if I understand the usage of this hardware correctly.
If a 1.6 GPF Toto toilet model CT705L...
were used with a Bocchi Tempo 370 Lever operated surface flush valve...
Would it work this way?
Here are the specs (only available for the push button version):
Thanks for any feedback.
For that bowl to flush, it needs 1.6 gallons.
Most domestic flush valves for use in the US, would have a 1" supply from the wall to the valve and an 1-1/2" tailpiece going into the bowl.
What you have is a 3/4" something, and I can't tell how much water that would put out.
It looks more like something a Urinal might have used maybe 50 years ago.
Originally Posted by Chris_G
Leave it to German engineering.
Schell GmbH + Co. KG: Schellomat Edition WC flush valve
Professional sanitary-ware installers, specifiers and building managers have long been aware of the advantages of wall-mounted WC flush valves... However, architects and customers were put off by these units’ outdated visual design and excessive noise. Schell Armaturentechnologie in Olpe, Germany, took this to heart and brought this tried and tested product back into the limelight at the ISH in the form of the newly designed Schellomat Edition WC flush valve...
The international juries of both the "reddot design award 2004" and "Design Plus 2005" were of the opinion that the clean-line elegance which the sieger design company lent to the Schellomat Edition was worth an award...
These new Schell flush valves have been designed with the important theme of saving water in mind – with a substantial flush capacity and a wide adjusting range from 4.5 to 12 litres. The Schellomat Edition Eco version also has an economy button allowing the flush volume to be halved.
READ THE FULL ARTICLE HERE:
Schell´s new wall-mounted WC flush valves have already won two design prizes
They might work on U.S. toilets once you got past the problem of adapting to the metric connecions.
The issue is not how many gallons per flush the valve provides. The issue is the RATE at which it delivers the required 1.6 gallons. That is why toilet flush tanks have 2 to 3 inch flush valves and often dump only the first half of the tank.
My 1.6 gallon toilet dumps 1.6 gallons in about 2 seconds as near as I can tell without instrumentation. That is 48 Gallons Per Minute! Besides the valve, you need a big pipe.
Low flow toilet desingers work hard to match the tank discharge to the toilet. My guess is that a non-standard flusjh valve would probably not work.
Ummm...not sure how to say this, but if your wife thinks the Model 370 looks phallic, you may want to see a urologist...
Well it must be standard to some toilet. They obviously designed it to work with something.Originally Posted by Bob NH
Chris_G, what is it about toilets you don't like, just wondering.
Have you looked at The Caroma Caravel 270?
I have nothing against toilets, I have a whole thread here dedicated to finding the right one. You seem to be saying, why don't I like "tank" toilets? Don't like them. I have my reasons. I'm not interested in a debate over tank toilets vs flushometer toilets. You can debate that on some other thread... my bet is, that thread probably already exists.
I'm looking for a flushometer that has had as much thought put into its design as hardware manufacturers are willing to put into faucets, shower heads, and other bathroom hardware. The flushometer, has been neglected.
Hansgrohe 38030 Axor Faucet
WS Bath Collection Sink Trap
Kohler stacked thermostatic valve trim
Why not put that much aesthetic throught into a flushometer design?
Schell GmbH + Co. KG of Germany has taken the time to address the issue. Why do you want to Poo-poo it? (couldn't resist the pun)
Because in this country, flushometer valves are almost universally used in commercial and some rental units where perfomrance, and not aesthetics, is the main consideration. When aesthetics becomes an issue they usually opt for a conventional tank type. You also have to consider who is going to repair these things, and the common "plant" service person is going to know how to fix a Sloan, but will have no clue, or parts, for an aesthetically pleasing one.
Sorry for asking....I didn't want to debate anything, I was just curious why you don't like tanks.
