Thread: well pump problem
    DIY Junior Member Jason Turner's Avatar
    Mar 2006
    NC
    Default well pump problem
    i just bought a house that had been winterized. after turning on power to the well and check that all valves are open i am having a problem
    i have great pressure at the spicket between the pump and the tank
    pump cycles on and runs until pressure is built and the pump remains off until a valve is turned on however the pressure at the house is low enough to stop with a little force using your thumb. i have taken the piping loose at the last valve in the line before entering house and the results are the same
    i can't understand why i have outstanding pressure at the well but not at the house
    am i missing a flow control valve or something done to the well system when it was winterized
    please help
    thanks in advance
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Check for a leak between the tank and the point where it enters the house. If there is no flow, the pressure should be the same throughout the system.
    This is a time for pressure gauges at both ends that you can check with and without flow.
    Previous member
    Jul 2005
    Riverview, Fl.
    Do you have any "whole house filters" in line anywhere. Or a water softener, iron filter etc?
    bob...
