Sweating Multiple Joints Close Together
Amatuer123
Quick question...I've read all the tips on here regarding soldering but need a few on soldering multiple joints that are about an inch apart. I soldered those pictured below one after the other w/ pretty bad results. I basically heated one at a time and then didn't have to heat the next as long. Set the fire alarm off w/ a little smoke. Also, should I just try again based on these ugly results? :rolleyes: Thanks! Joe
Amatuer123
Also...Reheated w/ some Flux 3 times
Also...I Reheated for 5 or so seconds w/ some added Flux 3 additional times w/ in approximately 1 minute each time. I did this because the joints didn't look sealed and I added some more solder... but it wasn't adhering that good or moving to the joint. Joe
Cass
The joints don't look to bad. Turn on the water and see if you have a leak. What brand of flux did you use, Oatey 95 pre tinning?
Amatuer123
Oatey
Cass, I'll run some water through them tonight; they are not hooked up to the supply yet; yes, oatey 95. Thank's for looking.
Plumber1
Florida
copper
When soldering multiple copper fittings I usually started with the bottom joint because it will be quicker to get the solder to flow at the upper joints.
So when you get the solder to flow quickly around the joint, you want to quit it and go to the next.
Then gently wipe with a rag or your finger if its fairly tough skinned.
Prashster
When I solder close joints - or even multiple sides of the same fitting, I tie a wet rag around one end and do one side at a time. Wet rags are good heat sinks. The only caution is that if you heat too long, the rag could ignite. This RARELY happens, though - but keep a bucket of h2o on hand J.I.C.
