Results 1 to 9 of 9
Thread: sealing roof jack
    DIY Member chetwynd's Avatar
    Jul 2005
    California
    Smile sealing roof jack
    Hi,
    The project I'm working on is actually electrical, but the same question applies. I have a piece of galvanized 3/4" pipe going down into a roof jack on a garage. Right now it's sealed with some kind of tar or putty or something that looks like it's been there forever. I need to replace the piece of galvanized pipe, and will then have to reseal where the pipe goes down into the roofjack. What should I use? 20mil tape?
    Talk to me fellas!
    THANKS!
    Feb 2005
    Default use silicone
    jsut buy a tube of clear silicone
    it works great
    Default seal
    Or a tube or can of roofing cement.
    Plumber Cass's Avatar
    Nov 2005
    Thoes will do the job.
    DIY Junior Member modbit's Avatar
    Jun 2012
    Atlanta
    That will work or roofing bull.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Just in case you didn't already know, you should use rigid conduit instead of plumbing pipe for electrical.
    Of course, that has nothing to do with sealing the roof penetration...
    The only real difference is that electical conduit has a straight thread, but I do NOT think electrical nipples are any different than plumbing ones.
    Aug 2011
    Santa Clara, CA
    Plumbing pipe isn't "approved" for electrical work. Not a big deal, other than an inspector might notice...
    Sep 2009
    Seattle. WA
    Electrical conduit is deburred, both at the threaded ends and internally. That is most emphatically not the case with the plumbing nipples sold
    most places, which could easily damage wiring pulled thru them. It is a big deal.
