We don't know what brand or model you have, but if it is a typical old stem with a flat rubber washer which you replaced, then you also usually need to replace a metal piece inside called the seat. It is the piece the rubber seals against. The seat unscrews. You need a special tool called a seat wrench; and you will need to take the old one with you to the store for a proper replacement.
