An ounce of prevention is worth a pound of cure.
Back in 1922 when I was young I was told that is the only to look at doing home repair projects.
If you have a older home, the poly barrier is considered the same as the kraft-faced insulation, just tightens up any chance of air movement.
There has been issues of walls "sweating" in regards to the poly barriers ontop of kraft faced but that was limited to super airtight homes, tyvek outside house wrapped and the fear of radon exposure in the home.
If you have an older home, more than likely the house has enough openings that allows the house to breath which is considered better in some circumstances. < That statement right there alone has probably saved lives with homeowners with leaking heat exchangers in furnaces that are emitting Carbon Monoxide.
Those who take really hot showers and the steam soaks the walls and ceiling; it might look clean, but mold can start to grow and not be seen. For example when my jacuzzi is filled with 80 gallons of water it reaks of chlorine from the treated water. The smell is horrible. Even the fan cannot remove the odor fast enough.
