Richard785
I have a tilled stall shower that has a slight smell coming from the drain. Over the past 10 years when this happens I just snake it and its been fine. The problem is there is some kind of white cement that is inside the drain pipe from the grill to the main pipe and each time I clean the drain more of this white stuff come off, its gritty so it catches hair.
I have two questions what is this white stuff and should I scrape it all off and put more if this on... (I did scrape a little off and noticed some rust on smaller drain pipe)
The shower is upstairs and show no leaking from the ceiling ... the house will build in 1988 so IM pretty sure its all PVC.
Thanks Richard
Thanks Richard
