Ed O'Neill
I have a problem with my well. The pressure switch is set @ 30/50. The pressure gauge gets up to48 psi and the pump keeps on running, all night if I don"t open the points. I have replaced the p/switch and get the same results. When I open the points the pressure stays at 48 all night unless i use some water.The tank at o pressure read 28 lbs. The points close at 28 instead of 30.
I can see the points on the right side spark and the left side does not. the voltage on each side is 110v. Any sugestions would be apreciated
