Your problem is not uncommon from what I have heard.
The pressure regulator will only work if the pressure in front of it is constant also. This means the pump will not be running when you first turn on the water. So the pressure in the tank is going to go down to the on setting of the pump. Once this happens, the pump will try to fill the tank again and will cycle off against a shower in most systems. You may consider a Smart Tee or a Cycle Stop Valve instead of your standard tank tee. This will keep the tank and pressure switch isolated while the pump is on and provide constant pressure once the pump is running. You can also go with a very small pressure tank with the Smart Tee so you will only have to run a 1/2 gallon of water or less to get the pump to come on.
bob...
