Jbschaefer1
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I just changed a defective and leaking pressure switch on my well and pressure tank setup. I shut off the well pump and breaker, turned off the main water valve to the house, and drained the water out of the pressure tank. Prior to doing this I noted the pressure gauge off the main line read approximately 45-50 psi. While installing the new Square D 30/50 pressure switch I noticed the defective switch was a Flotec 40/60. Once the system was turned back on I have noticed a pressure change in my water - shower specifically. In addition the pressure gauge on the water line reads only 30 PSI. What do I need to do? adjust the cut in screw on the pressure switch? Increase the pressure in the pressure tank? The house and well are only 2 1/2 years old and hopefully I haven't really screwed something up. If anyone can assist me I would greatly appreciate it. Thanks
