Convert Fleck 7000 Centaur carbon system to add chlorination / bleach injection?
wantonsoup
Colorado
After installing the Centaur system, that goes into a softener. Both use Fleck 7000. After about 6 months the water got progressively more stinky, sulfur smell. The iron level was low and there's no sludge in the toilet tanks (though there's a faint red line in the bowl at the water line). So we do have some iron. I did a bleach shock chlorination in the well but that only solved the problem for a few days.
I've been reading about bleach/chlorine injection and think that's my only real choice. The smell is driving us bonkers :p
On the website of a major water softener retailer I see they sell an "Eliminator" package which is a Fleck system with Centaur carbon, and also a bleach holding tank. Thinking if I can add the bleach tank to my existing system I'd be all set.
Any thoughts on how to do this easily? I'd love to not add another item into the mix if possible. Hoping I can add on to what I've already got.
Thanks for the insight.
I have that Eliminator with the bleach solution tank. 1.5 ft[sup]3[/sup] of CC. 15 gallon solution tank lasts 36 days between regens (every 3 days). Works for me.
Mikey
Hansville, Washington
Does that Eliminator system come with a contact tank? How big? A 120 gallon tank is common, but takes up a lot of room. A smaller "swirly" tank is said to accomplish the same thing as the larger, conventional tank. I've got one but haven't installled it yet. http://www.apwinc.com/retention_tank.html
Eliminator does not have contact tank. Solution tank solution oxidizes stuff picked up and held between regens. Solution tank does not get automatically refilled. I have a calendar application remind me.
wantonsoup
Colorado
I assume I could add the solution tank and setup programming on the Fleck. I just don't know where to buy it, what parts I'll need, and how to program it. :confused:
