Is this correct? Shower after toilet?
whackit
Los ANgeles
Hi folks,
Just proofing my work before I install. My main question here is if the shower downstream from the toilet is okay. It will connect via a wye directly to the stacks T. I'm not sure if those 2" count as wet venting or not.
Cacher_Chick
Test, Don't Guess!
The drain from the lavs to the water closet wye should be 2", and because the lav vent is venting the water closet, it must be within the max distance specified by your code.
The shower trap will need to it's own vent before the connection to the horizontal line, or if the framing allows, you could use a sanitary tee with a side inlet on the stack.
WJcandee
Wise One
New York, NY
Without a seperate vent for the shower, there is a substantial risk that the toilet will siphon the shower trap.
whackit
Los ANgeles
I believe the 3" vent on the right is what is venting the toilet, not the lavs.
I also think the shower will not siphon. It's a wye that goes straight into the san T of the 3" vent. I would put it straight into the vent if I had room for two tees or could find a combo fitting that worked.
WJcandee
Wise One
New York, NY
I'm thinking that you will find that Cacher_Chick knows her profession.
And I'm thinking that you're not really understanding venting if you: (a) don't recognize that you need to vent that shower prior to the Y or, alternatively, connect it directly to the stack and (b) don't think the trap in the shower is going to siphon when the toilet flushes if you install it without the required vent.
Tom Sawyer
Maine
The key here is distances and the code you are under. Under IPC everything is fine. The toilet doesn't need a local vent and if the vertical 3" is dry above the floor, it vents the shower just fine depending on trap to stack distance. Under other codes however, the distance from the toilet to vent may come into play and the shower would need its own vent. Unless your local code varies though, I believe that California will let you do that.
quote; I believe the 3" vent on the right is what is venting the toilet, not the lavs. I also think the shower will not siphon. It's a wye that goes straight into the san T of the 3" vent
In that case why did you ask for an opinion? BOTH of your "thinks" are wrong. The lavatory drain IS venting the toilet, (the 3" vent is inconsequential), and since the toilet is flowing PAST the shower connection, it can also induce siphonage. The 3" lav drain is "improper" unless you install a 3" cleanout on it. It may be allowed under the IPC, because the IPC is an "anything goes as long as it is easier and cheaper" code.
whackit
Los ANgeles
My apologies if my previous comments came off wrong. That was not my intent and I value everyone's opinion and expertise here tremendously.
My main problem I am having here is that the toilet is in the middle of a room and I can't access the wall behind it to vent because of a structural beam. The next nearest wall is 6' away. The main reason I wasn't considering the lavs as a vent is that they are roughly 10' away whereas the downstream vent is only 6'. Trust me that this is a nightmare scenario of structure/windows etc. I have very limited options.
Based on the comments I modified the previous layout which is preferred so I don't have to penetrate the top plate twice in a shear wall. Or Option 2 which splits the lava/shower and toilet into 2 separate lines.
Thank you again for all of your help I truly appreciate it.
