Shower vent, looking for confirmation
novaee04
Allentown, PA
Good Evening,
I am looking for confirmation that this is good. I believe that it is, but a second (or third) opinion would be appreciated. This is a shower drain. It goes into a 2" p trap, which wye's into the drain. The other end of the wye is the vent, it goes back, reduces to 1 1/2 and then elbows up.
One question, the other end of the drain elbows 90 into a horizontal drain to the stack. I was wondering if I need a cleanout anywhere in the shower leg, or just at the end of the horizontal drain going to the stack. Also, the end of that horizontal drain comes almost to a wall, so to make the cleanout useful, is it OK to use a wye to an elbow to the cleanout?
novaee04
Allentown, PA
Can I wet vent through a sink? How far downstream can it be?
Does a bathtub (no shower, just a bath) need its own vent?
Sean
quote; Every trapped fixture needs a vent.
But not every trap needs a dedicated vent. They can be shared if done properly. Your horizontal/flat vent would NOT be acceptable under most codes.
quote;The vent has to be downstream of the fixture, and must rise vertically off the trap arm.
Technically, the vent has to be AT the "P" traps connection to the drain system. "Downstream" can create "S" traps or other siphonage problems. This vent, even though it is horizontal, is at the connection point, so that at least is correct.
Sluggo
Washington
So, if he made the P trap connection over at the wall where the vent rises vertically, and made the whole drain 2", he'd be good?
