Low pressure and no water in pressure tank.
OldTSR
Idaho
I'm a brand new home owner and really know nothing about plumbing, all i know is that i have very little pressure. I was told to check the air pressure in the tank so i did and the tank has about 36 pounds in it. I just want to boost my pressure enough to be able to run a simple sprinkler or more than one appliance at once. Any advice? If i rembember right the well was rated at eight gpm, which i understand to be decent.
Don't measure the air pressure while you have any water pressure.
Look at your pressure gauge. What does it say? How were you determining you "have very little pressure"?
OldTSR
Idaho
I determined very little pressure by the amount of water that comes out of the spicket when i turn it on. So how do i measure the air pressure then?
Valveman
Cary Austin
cyclestopvalves.com
What does the pressure gauge on your tank say? The problem could be in the "spicket". I am guessing since you measured 36 PSI, that you have a 20/40 pressure switch. 40/60 is more common these days, so you might need to increase the setting of the pressure switch.
No matter what is causing the low pressure, it is your water system. You can have stronger pressure than any city supply, you just have to make it happen.
Turn off the power to the pump. Open a faucet and wait until the flow stops. Measure the air pressure. Add air if needed.
Close the faucet and turn the pump back on.
Wondering
Alabama
If you need to add air to the tank, it varies depending on your pressure setting.
20-40 pressure switch setting needs 18 lbs. air
30-50 pressure switch setting needs 28 lbs. air
40-60 pressure switch setting needs 38 lbs. air
If you need to add air, drain tank completely and add air to proper setting. If you need to raise your pressure, look under the pressure switch cover and there will be a short and tall spring with an adjusting nut on it. Turn the TALL one-this will raise your start and stop pressure. Turn it a few turns and then cycle the pump till you get to the setting you desire. All of this info is here on the site, above the posts.
Hope this helps.
Some of your problem may be with your faucets. If they have the water saver in the aerator you can take that out and help, that is if it is removable.
OldTSR
Idaho
After turning off the pump and draining the system, the pressure tank reads at 40 psi. using a tire gauge to check it. the gauge that is between the pump and the tank also reads at 40 psi. Should the two match pressure or should one be higher than the other?
OldTSR
Idaho
So if i understand right, the tank should be at 18, 28, or 38 lbs depending on the pressure switch setting?
The gauge on the tank should read zero at that point; you drained the system.
OldTSR
Idaho
I believe so, i turned off the pump and then opened a faucet in the house and let it run until no more water came out.
Wondering
Alabama
Do you know what your pressure switch off/on is set at? You probably need a new gauge. Then adjust air accordingly and maybe you will be fine.
