Quality multi-function handheld showerhead with pause function
NikiLC
California
Hello all,
I may be asking for the impossible, but... I am looking for the "perfect" handheld showerhead & would appreciate your thoughts & advice.
These are the characteristics I am hoping for in a handheld:
* Multi-function that would include a massaging function and also a directed/focused spray that would be good for washing dogs.
* The ability to temporarily pause the spray from the showerhead - for soaping the kid, dog, etc.
* High quality, but light enough to be functional when using as a handheld.
* The shape of the handle is comfortable to hold for small to large hands.
* The head itself is not so large/heavy/unbalanced as to make it unwieldy.
* Low water usage but strong flow.
* Comes in brushed nickel that does not have a slight yellowish tint (to me Delta & Hansgrohe's brushed/satin nickel are on the "warmer"/yellowish end of the spectrum).
Thoughts & recommendations?
Thanks in advance!
#2 would normally be a no-no, because a "pause" could turn in to a full time shut off which would cause all kinds of problems elsewhere in the plumbing system. Some of the other requirements are contradictory.
NikiLC
California
Sorry, I don't think I used the right terminology with the word pause. I am glad there are folks who do, but I don't understand the technical aspects at all.
I did do more research and found there is an American with Disabilities Act guideline that "to be ADA accessible, hand-held showers should include a non-positive shut-off control which turns off the flow of water using a control on the actual hand—held shower". So far I found the Kohler Forte hand held meets the guideline.
It's not surprising that some items on my perfect handheld wishlist are contradictory - what can I say, I want it all. :} Could you help me out in understanding the ones that I should give up on?
Thanks!!
WJcandee
Wise One
New York, NY
Yep Kohler Forte 10286, but it doesn't come in the color you want.
Also K-10343 comes in brushed nickel.
I think there is a lot of confusion on amateur and DIY sites about what 'non positive" means in this context.
NikiLC
California
WJCandee, I should have asked - can you clarify what non-positive means for this situation?
Thanks again.
