A couple problems with newly installed back to back toilets
BrianInStL
St. Louis, MO
Hi guys, first off - great forum! I've browsed many times for various tips and it's a goldmine.
On to my situation - Recently I installed 2 American Standard Mainstream 1.28 GPF toilets in my home. I know they are just about the cheapest toilets out there but I was just doing a quick remodel because I'm selling the home soon hopefully. My bathrooms and toilets are back to back.
First and biggest problem - When I flush one toilet the other experiences a decent water level drop in the bowl. It's bad enough that if I use one toilet a couple times then the other has to be flushed BEFORE using if you plan on going #2 if you know what I mean. The water level is already pretty low being a 1.28 GPF toilet so this is a big annoyance. This happens to both toilets.
From searching the forum a bit it seems it could be one of two problems - a clogged vent or a sanitary tee that lets water flow to the other side partially emptying the other toilet. I climbed onto my roof to take a look into the vent and flushed it out with a water hose - based on what I can tell it's not clogged. Now as far as the sanitary tee I do have one as you can see in the picture I attached but with there being a vertical drop of approximately 18-20" and then about 32" between the 2 toilet drains could the flushed water really make it all the way up to the other toilet? Are there any other suggestions as to what the problem could be? The old toilets didn't have this problem - I'm not sure of their age but would guess they were at least 15 years old.
My second issue it that one of the toilets seems to drip into the drain randomly. This happened both when it was the only toilet installed (while second bathroom was being renovated) and continues to happen now that both are in. It happens whether or not the toilet has been used recently and also while it is being used. I have tank level set to spec and it seems like the flapper is seated correctly. The water in the bowl and tank doesn't seem to drop much when it happens and the toilet never "kicks" on to refill. Sometimes it's a slow drip and sometimes it can be a pretty constant dribble. Maybe it's more of an annoyance than anything but does anyone have any ideas as to what the problem could be? The second toilet does seem to do it for a few seconds after flushing but I think that's normal right?
Any suggestions are welcome!
WJcandee
Wise One
New York, NY
Well if you are flushing one and the other drops, and you can prove that the drops happen contemporaneously with the flush, then -- YEAH -- it's your setup. Since the roof vent is clear, then the answer is that the other toilet is creating a suction on the other side and siphoning some water from the bowl. Entirely-plausible. And isn't your roof vent being clogged.
Don't guess about the leaky toilet. Check it with one of two methods. Either (a) close the water supply to the toilet, mark the tank level, and come back in 3 hours. If it's below the mark, you have your answer, most likely a leaky or non-seating flapper (or a cracked overflow riser); (b) drip some food coloring in the tank (I love this suggestion as if everybody just has it lying around), if it propagates to the bowl, then you have a little flapper leak.
A properly installed vent between the two toilets SHOULD prevent a siphonage from occurring, regardless of which fitting, (and technically, neither of the ones in the photos is the "right" fitting), is used. Water "splashing" across the fitting would fill the bowl, not empty it. If the siphonage is created by the water flowing quickly past the toilet's opening, that is caused by the Bernoulli Principle, which a "central vent" cannot control, but neither would changing the fitting.
hj,
You better look at the video again. The water in the bowl is being pushed upward and then slopping over the high part of the bend and out. It's losing a bit of water every time. It's not bein siphoned out, it's being pushed out.
Both TOTO and Kohler recommend the double way, and not the double santee or double fixture fitting. Terry Love
BrianInStL
St. Louis, MO
Thanks for responding.
As far as the dripping I have been meaning to test using those methods, just been a little lazy. I'll try to do it today and report back.
Now with the siphonage if it is suction causing it and changing the fitting to the double combination wye won't solve it then what next? I saw a post with a similar situation - the solution was a single wye was installed to drain each toilet and one of the toilets had to have a separate vent installed that then tied back into the main vent higher up. That would probably be too high of an expense and would require me tearing out walls that I just put in. Any other suggestions? Or should I just live with it?
DaveHo
SE PA
My take on it, the vent looks undersized. New toilets which use less water tend to evacuate the bowl quicker thus needing more airflow from the vent. Yours can't supply it, so it's suctioning water from the other toilet. Swapping the double sanitee for a double combo might help, or it might not. I'm not a pro, so don't take my thoughts as gospel.
This answer is wrong. :(
The water from the opposing bowl is not being siphoned out.
As water jumps from one arm to the other, it displaces air. It pushes air up into the opposing bowl. When air comes into the bowl, it raises the water level, and when that happens, the water then slops over the dam, the highest point of the trapway, and down the drain.
I am waiting for the rest of the plumbers to figure out this simple problem.
I'm waiting for the plumbing code to be re-written to solve this very simple issue. Both Kohler and TOTO are aware of this, I'm aware of it, and bit by bit, plumbing inspectors are being asked about it.
Cut out the double santee.
Replace with a double wye fitting. You don't want any water going up the other arm.
A double fixture fitting won't work either. It's not as bad as the double santee, but it's also not the solution. It also allow "water skip", which pushes air into the other bowl, thus slopping water over the trapway dam, and lose of bowl fill.
For venting, the 2" is fine. It's not the vent.
A double wye fitting on the left is okay.
A double fixture fitting is marginal, it will still lose water in the bowls.
A double Santee on the right doesn't not work well at all.
Jacky1eye
California
2) 3 X 4 closet bends entering into a 3X4X2 santee. 4" closet flange, 3" water closet, 2" vent 4" receiving stack.
Jack,
That's pretty much what he had, and that was causing probems. Repeating the the issue by installing a similar fitting, a fitting that both Kohler and TOTO in their instructions warn against, is not the fix.
If you have a toilet from the 80's, then the old way works. This is 2014, and times have moved on. It's time to get into the 21st century.
Vict
Twin Falls, Idaho
Any current solutions for this?
We recently ran into this problem, and swapped out the double santee for two santee's sitting on top of each other (we barely had the room for it if youre wondering) and we are STILL having an issue; not nearly as bad, but after 5-6 flushes of one toilet, there is a noticeable amount of water loss from the other toilet bowl.
Its a new house with new KOHLER toilets. We didnt supply the toilets so Im not sure on the model but of course its at least the 1.6 gal/flush.
Here is a video explaining why a bowl loses water when plumbed back to back with a double santee fitting when installing the new high performance toilets.
Karlos
Massachusetts
Not a plumber but have had the back to back toilet issues described on this thread. We have used late 80's toilets since day one with no issues. About 6 years ago we installed the oversized Kohler in the master bath and had no issues with the older toilet. Now, after replacing that one with a new smaller Koehler, the flushing issues started and it is on the new toilet. Flushing the new Koehler doesn't effect the water level in the other bigger Koehler. Flushing the bigger Koehler drops the water level in the new s'maller Koehler. After making sure that both water tank levels are the same(5 1/2") to the top of both tank rims, I happened to measure the rim height off the floor for both toilets. The bigger toilet water level is TWO inches higher off the floor than that of the new Koehler. Is the 2 " higher water level causing this tank drain problem with the new smaller toilet,?.
