venting question
mannix
mass
how would you go about venting a horizantal drain pipe with 6 lines coming into it. the line is 2" pvc with 1" pvc draining into it it will be horizontal with proper slope. Also this is for a fish tank not for a house. i need to know where the best place to place the vent would be. should i place one near each line coming in. can i place one at either end? also can i use smaller line to vent or does it have to be 2".
Does each of the six lines have a separate trap or is there only one on the system? If they do not have traps (and have say a drain valve), only the single trap needs a vent.
If each tank has a trap, each trap needs to be vented individually. THey can be combined at 42" above the floor or 6" above the flood plane of the highest one, whichever is higher.
The vent size could likely be 1.5", but it might help with a picture or diagram of what you're trying to do.
mannix
mass
i will try to draw up a picture at some point later tonight. there are no traps at all. this is not for a house and is a closed system. my drains will be going into another tank not the actual drain of the house.
In that case, a vent may not be needed at all. A diagram will help. A vent is used to prevent sewer gasses from coming out of drain pipes. If you have no connection to the sewer, I'm not sure why you'd need a trap.
mannix
mass
very basic pic
the blue boxes are the tanks the grey line is the pipes coming out of the tanks the black line is the drain line.
the reason i am asking about venting it is because i was having issues with air making its way back up the drain lines frokm the tanks before and it was causing alot of bubbles
Strictly Service
Licensed Plumber
MA
www.worcester-plumber.com
put the vent in before the last drain.put a tee in and run the vent 6 inches higher than the tanks. so per your drawing it would be:
Drain vent Drain Drain Drain Drain Drain outlet
The vent can be 1 11/2
Strictly Service
Licensed Plumber
MA
Put the vent in before the last tank. Put a tee in and run the vent 6 inches higher than the tanks. so per your drawing it would be:
Drain Drain Vent Drain Drain Drain Drain outlet. Should work.
