Hi There,
Looking for some insight\help on some plumbing work I had done a few months ago.
I needed a Water Softener installed as well as a new hot water tank and used someone that was recommended to me.
The job was done and everything seemed to be fine other than a substantial loss in water volume, meaning if one fixture was open it seemed to have normal water pressure but as soon as a 2nd one was opened the pressure dropped substantially. Two showers running is just about impossible.
I thought that the issue lied with the Water Softener itself but there is a bypass valve which I have used to bypass the Water softener and pressure(volume) does not seem to be any better.
I believe now that the issue is that the connections that the plumber used were too small for our house. 2500sqft two story 3 full bath + 1 half bath(more details can be provided if needed). It seems to me that the main water line is ¾ and the connections that he used are ½. Is this able to be confirmed through the attached Picture? Can anyone let me know if this could\is causing my issue.
Should I have the plumber back to fix or find a new one? Not dying to shell out more $$ and not have it fix my problem. Any help would be greatly appreciated. Thanks in Advance
57Chewie
57Chewie
