Is this really true?
gcsherwood
Florida
Local water softener guy told me that if I used any water while the softener was regenerating I'd be pulling brine through my system rather than simply hard water (or nothing, which would be fine if the unit simply shut off the flow of water during regeneration). I think my WaterBoss city water filter just gives me hard water (at least I've never noticed any saltiness, and I've never not had water -- to my knowledge, anyway, but I've used one for ten years). I'm looking at a Fleck 7000sxt valve. What does it do while the unit is regenerating?
thanks
geoff sherwood
SHR
Minnesota
The brine statement is BS. Kick him out of your home or run from him. Your WaterBoss has an automatic by-pass valve which allows un-softened water to flow in to the home when the softener is regenerating. That is why the WaterBoss units all have a user programable regeneration time - factory default 2am. For most homes 2am is a low water usage time so maybe you get 3 gallons of hard water into the home system when the toilet is flushed in the middle of the night. No big deal.
Someone else will be along to tell you about the Fleck valve characteristics.
Mialynette2003
Ocala, Florida
Most all water softeners have an auto bypass while in a regen. You really don't want to be using a lot of water during a regen and that is why it is set for a 2 AM regen.
ditttohead
Water systems designer, R&D
Ontario California
All modern softeners bypass hard water during the regeneration process. The 7000 is no exception. Please see the attached drawing below. It shows the water flow path inside the valve during the brine and rinse cycle. All cycles except for brine fill are hard water bypass. The only other type of design that is normally available, but not common in residential applications is no treated water during regeneration. This simply shuts the water off to the outlet of the system during the regeneration process. It is used commonly in commercial applications. Send me a PM, let me know who this guy is. I know a lot of dealers in your area, most are excellent, obviously this one is not.
