Youngstown Sink Removal
Gravity
Norwood, MA
Hi all,
Does anyone have any past experience removing one of these beasts? Does the countertop detach from the metal base cabinets? That's really my biggest concern. If so, how? I have a guy who wants this for his retro kitchen project so I'd rather not take a sledge to it. Any advice is much appreciated. Thanks! SAM_5045.jpg
Gravity
Norwood, MA
As an update, in case anyone came here looking for answers, I was able to remove this last weekend. Just had to run a utility knife under the sink top to break up the caulking and shimmy it around, I think it pulled forward and I lifted up. Didn't weight more than 75 pounds which was nice. The steel cabinets were not secured to the wall or floor so I just lifted that out with help from someone else, again, not more than 75 pounds maybe. Went way smoother than I thought. There were brackets which looked like they could bolt the top down to the cabinets but that was not the case for me.
Usually, the sink was secured to the cabinet with four bolts. The cabinet and sink came as an assembled unit and you just set it into place and connected it. You were lucky with that one because it used a conventional faucet. The earlier ones used a proprietary backsplash mounted one.
DMNTG
Montana
Hi All,
I am having the same issue. I have a client with a vintage Youngstown cabinet and sink who want me to change out the sink. I cannot figure out how to remove the old sink, though, short of pulling the entire cabinet set away from the wall and dismantling the whole thing. Any ideas?
Thanks so much!
Dj2
California
First look under the sink to see whether and how it's attached to the cabinet.
From the picture, it looks like the stainless steel brackets around the sink are also holding the sink in place, remove them and maybe you'll find a way to pull the sink out.
DMNTG
Montana
Really appreciate your reply. And yes, you're right. However I can't figure out how to remove those SS trim pieces. The same for the SS backsplash. Looking underneath, I did see some screws that are holding the sink down in the frame but it's the trim pieces that have me stumped...and the backsplash.
DMNTG
Montana
Also there is a dishwasher to the right and corner cabinet to the left. It looks like the entire assembly was put together away from the wall, and then pushed back against it.
