That would be an Aquavar Variable speed controller, which is also known as a VFD for Variable Frequency Drive, or VSD for Variable Speed Drive, “Freak” drive for short, or it can also be called other names.
Power from a VFD causes Harmonics, voltage spikes 4X the supply voltage, and bearing currents also known as EDM currents that cause fluting of ball bearing races and pits in the balls themselves. This actually happens worse when the bearings are lightly loaded. Without much of a load the balls in the bearings don’t touch the races. The balls just spin in the lubricating grease, basically insulated from the races, which prevents any grounding. The EDM currents from the VFD create a little “lightning storm” when the bearing is spinning. The “lightning” discharges across the grease insulation and causes Electrical Discharge Machining or EDM in the bearings.
Pump manufacturers know about this and actually use it to plan the amount of time they want your pump to last. You should just be happy to replace your pump every 3 to 4 years. If you had a regular pump, running on standard power, it would probably last 30 years.
The quote I have heard several times is this. “Pump companies cannot stay in business making pumps that last 30 years.” They have engineered their pumps to last no more than an average of 5 years. They use cheaper, non-grease-able, sealed bearings. They shorten the motor length to make it run close to a critically hot temperature, and do other things to make the pump/motor fit within their time limit for planned obsolescence.
On larger motors they are now using brushes to ground the rotor in the motor, and insulated bearing races. Insulated races (plastic) are not as strong as standard steel bearings, and grounding brushes wear and therefore need regular maintenance.
However, some people have learned how to solve these problems and still get water delivered at a constant pressure. Controls like the Cycle Stop Valve can make a cheaply built pump that was designed to last only 5 years actually last 15 or 20. By simply eliminating the repetitive on/off cycling, and reducing the amp draw of the motor when using small flow rates, the CSV makes the motor run cooler and last longer than designed. The CSV does this while delivering constant pressure water, the same as a VFD. However, the CSV is a simple mechanical valve that does not distort the power to the motor, cause voltage spikes to the windings, electrical fluting of the ball bearings, or many other problems associated with VFD’s.
Some pump manufacturers are now designing the VFD to fit inside the motor. This way you have no way to circumvent their planned obsolescence by using a CSV.
In your case being able to grease the bearings would not help. It is the EDM currents that have destroyed your bearings, not a lack of grease. The worse the bearings get, the louder the noise, until someday soon it won’t make ANY noise, because the bearings are locked down.
VFD’s also cause a high-pitched whistling noise from the motor. This “whistling” is probably at about 4KHz, as that is the standard carrier frequency used with most VFD’s. You can reduce the “whistling” by changing the carrier frequency of the VFD. But not running the carrier frequency at its optimal range can cause other side effects.
I am sure someone talked you into the VFD by saying it would save energy and the soft starts will make the pump last longer. These are the lies they use to con people into purchasing a VFD, which is a “Cash Cow” for the manufacturers, and consequently a real “money pit” for the pump users. They have even conned Utility Companies and Government agencies like the DOE into offering incentives or tax breaks for installing VFD’s, because they supposedly save so much energy.
VFD’s do not save energy or make pumps last longer. There are several states that are now mandating Variable Speed Pumps to be used for swimming pools as well. VFD’s are used to make you think energy is being saved, so you won’t mind paying much higher prices for pumps, and won’t mind replacing them every couple of years, instead of having a pump that would last 30 years as it should.
Since I am already on my soapbox, let me say this. VFD’s do not save energy. Adding Ethanol to gas is a really bad idea. The government cannot spend us into prosperity with “Stimulus Money”, or manage our health care any better than they manage a freight delivery service (Post Office). Big government is not out to help us, but control us to line their pockets. If we don’t educate ourselves on these and other subjects, the fall of Rome will seem trivial next to the demise of our own country.
I’ll bet you never thought the little water pump for your house or swimming pool could be part of the Global Warming Conspiracy, but it is.
Fluted bearing race.
