Fleck 9000 valve leaking
Martin1b
Bill
Kansas
I have a fleck 9000 twin that is leaking. I'm not a plumber but am willing to do the repair myself if it's possible. When facing the valve with cover off, there are 2 bores on top of each other to the right of the timer wheel (picture attached). The top cylinder is leaking. I've been told this is a seal replacement job, and potentially a piston replacement. Does this sound right?
Couple of questions:
1) How difficult is this to do and
2) Where can I get good quality seals?
Bill
Akpsdvan
Alaska
Bill
It would be good to replace both the upper and lower pistons along with the upper and lower seal pack kits, the lower one has the front half and then the back half when it comes to seals and spacers.
There are the 7 screws that hold the back plate to the valve body and then the screws that hold the shaft to the upper and lower cams..
simple enough
Just make sure that the parts are Fleck/Pentair and not a cheap knock off....
There are on line companies and then the auction site will often have the parts at a better deal...
Mialynette2003
Ocala, Florida
Is it leaking from the stem of the top piston? Look to see if any of the teflon coating is worn off. If so, you will need the replace the piston. You can get the piston online at softenerparts.
