Thread: Wall hung toilet carriers
    Plumber Cass's Avatar
    Default Wall hung toilet carriers
    I have an old Kohler wall hung toilet in their famous yellow that I am replacing. Does anyone know if the carriers are adjustable. I am installing a Crane and I don't know if I need to order a new carrier or if the old one can be adjusted to fit the Crane..
    DIY Senior Member Mikebarone's Avatar
    Feb 2006
    Phoenix, AZ
    Default Just a suggestion…
    You might try contacting Kohler or Crane, or both on that one….good luck.
    P.S. E-mailing works great because you can send photos!
    Default carrier
    The only toilet that need a "non-standard" carrier measurement was the Case/Briggs 1000/3000 series. All the rest, except for prison blowout bowls, are interchangeable.
    Thanks you hj
