Toilet seat wiggling
Singlemom1950
Arkansas
My toilet seat shifts from side to side. The problem seems to be that one of the screws is loose in the hole provided in the porcelain. Could I fill the hole with caulk or liquid nails or something like that then drive the screw into that filler?
WJcandee
Wise One
New York, NY
Well, in most cases, the bolt isn't designed to completely-fill the width of the hole. Rather, the wiggling is prevented by the bolt and nut being tightened down, on which side depends upon the design of the hardware. I would that whatever the appropriate tools are and tighten the thing up. Straighten it out like you like, then tighten both sides.
There are enough designs that it's hard to generalize too much, but that's the basic idea.
I think I have seen nuts that came with seats that had a bushing or conical piece that would center the bolts in the holes.
https://www.ginsey.com/product/toilet-seat-tightening-kit includes bushings , but I expect bushings could be found elsewhere.
Cwhyu2
Consultant
Cincinnati OH
You could also buy a new seat.Easy to install and you can get them at any hardware
store.
