help identifying shower valve. Delta Monitor 17
justme1977
PA
Hello I was hoping someone could help identifying this shower valve
It leaks so I'm hoping to replace the cartridge but not sure what to buy or how to take it apart
Smooky
North Carolina
Unscrew the chrome part and then you should be able to pull it out.
I think it is a Delta, it looks a lot like this:
The chrome sleeve slides off when you twist and pull it, then you CAREFULLY unscrew the large nut underneath it. (if it is tight and you are NOT careful, you will destroy the valve). There are several "similar" stems, depending on its age, so you have to take the old one to compare it.
