p trap above drain pipe #2
sharkie
Maryland
How would an experienced plumber change out the piece that is coming out of the wall on this drain pipe. Is it possible to unscrew elbow piece that is glued to the pipe that goes into the drywall? Will we have to cut it with a sawzall somehow? And if so after cutting it what king of fitting would allow me to put a ptrap through the rectangular hole that I am going to cut in the shelf? Thanks everyone in advance!
Gary Swart
Yakima, WA
Do you know that what you have is an illegal S trap? The shelf will prevent a proper P trap. Suggest you read up on P trap vs S trap.
The correct way to fix this is to open up the wall, and move the fitting there up so that it can be at the proper elevation for the trap arm. The trap arm MUST come off the trap straight AND be vented before it can turn down.
Cacher_Chick
Test, Don't Guess!
Yep, what you have done there is going to lead to sewer gas and drain flies coming in through the drain. As others have said, the trap must be lowered or the fitting in the wall raised. You cannot use bends in the arm of the trap because it will prevent the vent from working properly.
I think OP is planning to do something like this, but with a big clearance hole in the shelf and no foam.
He is asking how to get a pipe to come out horizontally to meet his lowered P-trap.
is another picture, but the clearance in this case will be a big hole in a shelf.
Jim Mills
nebraska
You'd have to cut that fitting off as close to the wall as possible, then use a inside pipe cutter to cut the pipe as close to the san tee as possible, then use a ram bit to cut the pipe stub out of the san tee, then glue in a new section of PVC, then a trap adapter, and you only get one shot to get it right, and a ram bit aint cheap, and if it doesn't work, you are going to have to cut the wall open and replace the san tee, which is what I would do. Then cut your hole in the shelf, but do a neater job that what is shown in Reach4's pics!
