Hi,
I need some advice on where I can tie into drainage for a new sink I will install in my basement.
I have three 4 inch pipe openings with caps on them in my basement floor. One of the cap is installed at a slant which I'm guessing is the clean out. The other 2 are installed vertically straight up. When I open up the vertically straight up caps, one of these have water filled about half way up. The other does not have water in it and bends at about a 45 degrees down. I tested both of them by pouring water into them and they both drain fine. I did another test where I turned on the tap of a sink on the main floor and I can hear water flowing from the opening that has the 45 degree bend. The house was built in 1975. Which of these can I tie my drainage into for my basement sink? Thanks.
