Thread: when to use NPT and when to use sweat
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default when to use NPT and when to use sweat
    I need 2 sets of circulator isolator flanges. There are two different types: NPT and Sweat.
    Usually when we should use NPT and when we should use solder?
    Do you think this isolator flange from Taco is good? http://www.sdsmarket.com/Taco_SF_100..._p/sf-100s.htm. It seems different with others.
    If you have threaded pipe, that would be one reason to use NPT
    When I'm working with copper pipe, I prefer soldering. It's one less thing to go wrong. And, at my age, I prefer anything that will assemble without pipe wrenches.
    I have to keep my wrists in shape for softball.
    The "pipe" you are working with usually dictates what kind of flange, or connection, you use. However, if you are working with steel pipe, you would normally only use a threaded flange. If you have copper then you can either solder the flange on, or convert to an adapter and screw the flange on. In this case, it would depend on what kind of flange you have.
  1. Toilet Sweat
    By molo in forum Toilet Forum discussions
    Last Post: 05-16-2011, 08:46 PM
  2. Can you sweat???
    By balthomeown in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2008, 06:08 AM
  3. No Room to Sweat
    By BS in forum Shower & bathtub Forum & Blog
    Last Post: 02-17-2007, 06:23 AM
  4. compression vs sweat
    By fast pasquale in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2007, 05:33 AM
  5. Sweat or Compression?
    By teamo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2006, 09:12 AM
