Results 1 to 7 of 7
Thread: 2" copper dwv in kitchen
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default 2" copper dwv in kitchen
    Hey all,
    I have a 2" dwv in my kitchen and wanted to get this setup for my new sink, and cabinets that are coming in.
    I know the usualy fittings for a kitchen sink drain is 1-1/2". So to get this to connect to the 2" copper dwv, do I:
    1. Get a 2 in. x 1-1/2 in. Copper DWV CxX coupling and put on a trap adapter?
    http://www.homedepot.com/p/Mueller-S...7073/100132768
    or
    2. get a 2" reducer to 1-1/2" and put a trap adapter at the end of this?
    THank you!
    Normally a kitchen trap arm is 1.5"
    If you have a 2.0" trap arm, it will need to be reduced to 1.5" and a trap adapter.
    This is 1.5" copper DWV, from and old 60's home. They also make couplings that transition between copper and plastic.
    If I read your question correctly, both of those fittings are the same, but you can do it almost anyway you want to as long as you wind up with a 1 1/2" connection to the sink.
    Jun 2006
    New York
    Thank you Terry and HJ! I'll post pics when I can.
    Jun 2006
    New York
    Hey guys,
    Ok, so I was successful in getting a copper 2"x1-1/2 reducer. Now when I put the 1-1/2 trap adapter to the reducer size, its the same size and it won't fit. Did I buy the wrong piece?
    No, you need a short length of 1 1/2" copper to go between the two pieces.
    Jun 2006
    New York
    Thank you HJ.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. Protection for "exposed" outdoor copper drain pipe?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-23-2013, 01:29 AM
  3. Termosyphon system and closed loop copper heat exchanger "dillema"!
    By leaualorin in forum Solar and Geothermal Water Heating Forum
    Last Post: 11-27-2011, 02:02 PM
  4. How to go from 1/2" copper to 1/4" compression fitting, with a ball valve inbetween
    By Studly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2011, 01:11 PM
  5. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2011, 04:51 PM
