drainpipe behind dishwasher blocking new install
frank84
NYC
I'm replacing a dishwasher from the early seventies. The problem is the new Maytag MDB8959SBS dishwasher won't accommodate the drainpipe behind it. The motor is too low and to the left. Any recommendations on the most elegant solution?
Thanks for any advice.
Jim Mills
nebraska
Any way to run the drain line to the kitchen sink drain or disposer? That water line is going to have to dealt with as well.
Cacher_Chick
Test, Don't Guess!
Commonly, the dishwasher is installed to one side of the kitchen sink, and the drain hose from the dishwasher tees in above the sink's trap. The water supply to the sink is also shared with the dishwasher.
frank84
NYC
I was hoping to keep this setup as is. Though should be fairly easy to run the drain line to the kitchen sink.
I am going to assume this setup is against code? Are you both suggesting to cap the drain behind the dishwasher?
As you can also see, there is also a separate water supply for the dishwasher, bottom left of pic. However the current dishwasher accommodates it just fine. Remove this as well?
Thanks for the assistance.
Gary Swart
Yakima, WA
What you have is not a proper DW connection. The drain on a DW must use either a high loop or an air gap. In either case, the drain line goes up to the counter and then into the sink drain line. I suggest you eliminate that contraption you have and follow local code for DW drain connection. Some areas allow the high loop, but some require the air gap. The air gap is always legal everywhere.
frank84
NYC
Thanks guys. I capped the drain behind the dishwasher, and am going to connect a drain (with an air gap fitting) to my sink drain line. I'm going to leave the water supply right where it is.
quote; I capped the drain behind the dishwasher,
Good, because you not only had an "S" trap, but if the drain valve leaked you would not be able to keep water in the dishwasher.
