Thread: Do water hammer arrestors wear out?
    DIY Junior Member ArtBacon's Avatar
    Feb 2014
    Minnesota
    Default Do water hammer arrestors wear out?
    I have a 5 year old "High Efficiency" LG washing machine. The intake valves open and close so fast it cause a pretty strong water hammer. When I had the washer delivered and hooked up, I put a water hammer arrestor on the hot an cold intakes. The water hammer noise seems to be getting louder again. Do these devices wear out, or are there some that work better than others? Thanks
    Feb 2011
    NW Ontario, Canada
    You don't say what style of arrestors you used. The type that have no moving parts cannot possibly wear out but they can get waterlogged over time as the air gets absorbed into the water.
    The gas charged piston and O-ring style could wear out if there is sediment.
    They can wear out.
    They make some that fit right on the washer, and the hose threads onto that.
    It is not so much that they "wear out", but rather the "O" rings lose their lubrication and so the piston gets stuck and cannot move to absorb the water shock.
  1. Sharkbite Water Hammer Arrestors
    By Dinger928 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2009, 03:56 AM
  2. Do I need water hammer arrestors?
    By noreast in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-12-2009, 05:46 PM
  3. Water Hammer Arrestors
    By hijacker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2008, 08:04 AM
  4. Water hammer arrestors not working?
    By bobwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2008, 02:36 PM
  5. Water hammer arrestors
    By em2hurley in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2005, 01:09 PM
