Results 1 to 10 of 10
Thread: submersible pump inducer sleeve help
    DIY Member Johnny Turner's Avatar
    Feb 2014
    Kentucky
    Default submersible pump inducer sleeve help
    So I just got a countyline 3/4 hp submersible pump that I may have to use in a storage tank .I read online that when in an open body of water you need to use a flow inducer sleeve .The temp specs on this countyline is less then 120 f .Does anyone know the best way to construct one of these inducer sleeves or have any info on this subject?This is what I have found on the franklin motor site.
    http://www.pacificliquid.com/inducer.pdf
    Jan 2008
    You need to maintain flow around the motor. It looks like it would be easy enough to make one out of a piece of 4" PVC, just like it shows in the picture.
    Feb 2014
    Kentucky
    Quote Originally Posted by Reach4 View Post
    One thing that I question is how is a 4" pump is going to fit in a 4" pvc pipe? wouldn`t it have to be bigger then the pump diameter in order for the pump to fit and still have water flow around it??Or is the pvc over 4 " and how much space around the motor that leaves for water flow.
    Sep 2013
    "4 inch pumps" are normally around 3-3/4 inch.
    The thinner " PVC pipe with thinner wall ( e.g. SDR 35)" oddly has an ID that differs, but is just under 4 inches. http://www.lowes.com/pd_24140-1814-P...C_4294765358__ is an example. http://www.all-about-pipe.com/pvc-pipe-dimensions.html
    Schedule 40 is just over 4 inches ID, but has thicker walls. So you would probably need more cuts and firmer clamping.
    http://www.youtube.com/watch?v=sVBpCVqX7Jk shows a flow inducer being put on a bigger pump.
    http://www.wwpp.co/4-pvc-pump-sleeve.html is an expensive version.
    http://www.cheapapumps.com.au/submer...mp_shroud.html says centering bolts are important. I don't know that they are, but it is not going to hurt if they don't rust.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Actually, 4" pump motors are 3 7/8 inches and they fit perfectly into 4 sch 40 PVC.
    Use a piece of 4" PVC a foot longer than the pump and use a 4" abs well seal to make your flow inducer and secure the sleeve to the drop pipe.
    Feb 2014
    Kentucky
    Quote Originally Posted by craigpump View Post
    Looks like the abs well seal would be the easier way to go no cutting clamping or taping.Thanks guys for the info looks easy enough to do.
    Feb 2014
    Kentucky
    Ok guys I got some sdr 35 like that site suggested for my inducer sleeve it`s green but I`m worried is this this sdr 35 sewer pipe safe for drinking water ?
    Apr 2012
    ct
    Just because it is made for sewer doesn't mean it won't work for potable water.
    But slotting, slicing, clamping and taping it to the pump is a 1/2 assed way to do it. Especially when you can make one with an abs seal and a piece of sch 40 for about $20.00
    Feb 2014
    Kentucky
    I done got a well seal for it don`t know if it is abs but it`s a 4" well seal .So that sdr 35 sewer pvc is safe for water then I take it?
  1. flow inducer sleeve question...
    By T_Allen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2013, 05:32 AM
  2. Cycle stop valve and flow inducer sleeve
    By jackbombay in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2012, 10:58 AM
  3. Flow Inducer Sleeve; Need fine details, bolt size, etc
    By JohnD2007 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-07-2010, 12:33 PM
  4. Add on draft inducer
    By Garydaplummer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2008, 06:27 AM
  5. problem w/ draft inducer
    By jkmdotu in forum HVAC Heating & Cooling
    Last Post: 11-26-2007, 07:00 PM
