Results 1 to 6 of 6
Thread: measurement questions
    DIY Junior Member Daniel Bigdan Frazier's Avatar
    Feb 2014
    south carolina
    Default measurement questions
    20 x 17mm 4/5" x 43/64
    I've researched how to divide this formula up to better understand and know each dimension and what each measurement corresponds with but the only part i understand is 4/5 is the outside diameter.
    so can yall tell me how to break this up piece by piece?
    redneck engineer
    Sep 2013
    Nobody is going to figure out what you are asking from this posting. I only figured that out from your other posting that was a little more coherent, and where you got useful info: take it to the store and see what thread fits.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Daniel Bigdan Frazier View Post
    Your measurement conversion is off a bit.
    20 mm = .7873992 inch (4/5" = .80 inch)
    17 mm = .6692893 inch (43/64" = .671875 inch)
    What are you having a problem with ?
    Jan 2008
    Plumbing pipe fittings are standardized. You are working to hard at being an engineer instead of just getting the job done.
    Mar 2011
    Houston, TX
    Very few Metric sizes will come out being a even fraction in inches.
    The USA was going to go to metric, But I never seen it happen, but we did learn it in school.
    China parts do not match US made parts if you get your Micrometer out and measure.
    Have Fun. Were is the other thread ?
    quote; the only part i understand is 4/5 is the outside diameter.
    That is the only dimension you need to know. Your faucet has a 20 mm outside thread so you need a 20 mm to 1/2" ips female adapter, then you can convert to your hose thread from that.
  1. Water hardness, city report vs home measurement
    By teve in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-13-2011, 09:09 AM
  2. A few pex questions and Sharkbite brand pex questions.
    By lee_leses in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2011, 02:43 PM
  3. How critical is valve to spout measurement?
    By jadnashua in forum Shower & bathtub Forum & Blog
    Last Post: 05-13-2010, 09:32 PM
  4. Door measurement question
    By richrc1131 in forum Remodel Forum & Blog
    Last Post: 04-25-2010, 10:16 AM
  5. 11-1/4" measurement from wall to bolt
    By planosteel in forum Toilet Forum discussions
    Last Post: 10-15-2006, 11:21 AM
