Results 1 to 6 of 6
Thread: Proposed schematic for adding washing machine and kitchenette
    DIY Junior Member mystryda's Avatar
    Jun 2010
    Dayton, OH
    Default Proposed schematic for adding washing machine and kitchenette
    I'd like to add a 2nd-story washing machine and a basement kitchenette to what I believe is a 2" vent for a floor drain. Would you review the attached schematic?
    I'm guessing about how the existing floor drain is plumbed, since everything's encapsulated in the basement floor. What I see is the floor drain itself and a 2" line that comes out of the floor a few inches away disappears through the ceiling. I'm assuming that this is a vent line. How would I verify that assumption? I'm thinking to break the line, then pour water down it to assure that it connects to the sewer (does this really tell me?) and blow air up it to assure that it vents.
    This is in Virginia, so it's under the IPC.
    You will need to bring in the washer and the sink "below" the venting for the floor drain. Either that or plug or cap the floor drain. Running either of those can siphon that trap.
    Wet venting is only done on the same floor, and not by kitchen sinks or washers. Especially not by washers.
    I see you breaking up some flooring in your future.
    Jun 2010
    Dayton, OH
    Thanks for the quick reply, Terry. I love your site.
    So would this be right, then? (Moved the floor drain "upstream;" sorry, the drawing got a little cramped.)
    Will the 2" connection to the main floor drain be able to handle both the washing machine and the sink/dishwasher?
    The second drawing works !
    Jun 2010
    Dayton, OH
    Default Listening through water
    So I've got the floor open and I'm trying to find the main drain. I'm 30" down, which is a little deeper than where I need to be, assuming 1/4" / ft drop from the toilet flange across the basement (gives 28").
    I pulled said toilet and fed down a cheapy snake. I got someone to wiggle the snake back and forth and I can hear it, but frustratingly I can't find the pipe.
    The water table is really high right now, so the bottom of the hole is covered with water. Are there any tricks to listening through water? Will sound always come straight off the face of the water, or should I be able to hear which direction through the water? Like I said, I can hear the snake rattling, but I can't find.
    Jun 2010
    Dayton, OH
    So I finally made my splice into the 4" horizontal main drain.
    I know that the 2nd floor waste needs to enter before the 1st floor waste. Is it acceptable to have them merge in a horizontal section, like so?
  1. Adding Basement washing machine to soil stack help
    By codyvm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2012, 12:53 PM
  2. Adding Kitchenette to basement with drain above floor
    By stonejohn9 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2011, 02:42 PM
  3. adding shower to half bath using washing machine plumbling
    By rhoxsie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2008, 06:43 AM
  4. New Washing Machine
    By Barneyn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2007, 12:07 PM
  5. Adding washing machine to drain line
    By Mark Jones in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2004, 03:29 PM
