Thread: Can i service stem which appears to be source of leak in watts ball valve?
    DIY Junior Member
    Feb 2014
    Texas
    Default Can i service stem which appears to be source of leak in watts ball valve?
    Trying to upload picture
    DIY Junior Member
    Feb 2014
    Texas
    Sorry it got turned sideways
    If you pull the handle, you may find something like a bonnet nut that can be snugged.
    If you have the correct size, "ignition open end wrench" it will fit under the handle so you can tighten the packing nut. If not remove the handle and tighten the nut.
  1. Stem Leak on Older Nibco Ball Valve
    By wraujr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2013, 11:58 AM
  2. Ball valve stem leak
    By jwray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2012, 07:35 PM
  3. Ball valve stem leak
    By jsadik in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2012, 04:03 PM
  4. Leak at ball valve nut
    By spta97 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-25-2009, 05:05 PM
  5. new ball valve leaks at stem
    By Kevin G in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2008, 11:10 AM
