Results 1 to 5 of 5
Thread: Drain issue
    DIY Junior Member jjgmorgan's Avatar
    Feb 2014
    Tennessee
    Default Drain issue
    I have a washing machine with 2" drain, properly vented. Can I connect the drain of my bathroom sink which is vented, to that same 2" drain.
    There are several ways to combine those.
    Some are right, some aren't.
    Here is a laundry tub and washer.
    The tub to the left could have been a lav, which roughs a bit higher.
    Feb 2014
    Tennessee
    In my case I have the washer drain pipe running alone a wall meeting the lav drain pipe at 90 degrees alone the other wall. The 2" washer drain continues in a straight line. Which coupling do I use to connect the two? May be a wye & bend? Can a wye & bend be installed on its side. In the photo a sanitary T is used, I understand that a sanitary T can not be installed on its side.
    CAN you do it" Maybe, it depends on HOW you make the connection and we don't know how that is. Your description is too confusing to try to follow HOW the pipes meet or are installed, or WHY you have to do it in the first place.
    Feb 2014
    Tennessee
    I was just trying to get an understanding as to which drain fitting to use when two drain pipes meet and join at right angles in the same plane. I wanted to consolidate some drains to avoid more holes through the floor. All the examples I am getting are when the waste pipes join to a vertical line, not two joining in a more horizontal connection.
  1. Laundry tub drain issue
    By ddmoit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2012, 09:19 AM
  2. washer drain issue
    By rjherald in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2011, 08:37 AM
  3. Tub Overflow Drain Issue
    By dgibson32 in forum Shower & bathtub Forum & Blog
    Last Post: 01-23-2010, 07:02 AM
  4. Yet another shower drain issue ...
    By kk3 in forum Shower & bathtub Forum & Blog
    Last Post: 01-01-2010, 06:35 AM
  5. Tub Toilet Drain Issue
    By Ray Scott in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2008, 03:02 PM
