Results 1 to 10 of 10
Thread: Compression fittings and brass pipe
    DIY Junior Member Gravity's Avatar
    Oct 2013
    Norwood, MA
    Default Compression fittings and brass pipe
    Hi, I was going to install shutoff valves on existing 1/2" brass cold and hot water lines. Can I use valves with 1/2" compression inlets? Do they play nice with brass pipe? Or should I use 1/2" sweat connection?
    If I sweat it, is there any need to modify my copper pipe soldering technique for brass pipe?
    And before anyone mentions it, I know PEX is awesome and the greatest thing since sliced bread, blah blah blah but it isn't in the budget for this renno.
    A threaded brass nipple needs threaded stops.
    1/2" copper can use either sweat on stops, or compression.
    1/2" copper is 5/8" OD
    Oct 2013
    Norwood, MA
    Thanks for the response, Terry.
    As a hypothetical, what if I cut back existing brass pipe with a sawsall and there was no threaded end left? Could you use compression on that?
    Thanks again.
    Quote Originally Posted by Gravity View Post
    Thanks again.
    I would not do that.
    I'm not aware of a compression fitting for those. There are plenty of stops that thread on though.
    It's an easy job to spin on a new stop.
    Oct 2013
    Norwood, MA
    Excellent, thank you Terry!
    Best,
    Mike
    There are no "compression", or solder, fittings for brass pipe. They are threaded and screwed. What are you trying to do? How about a picture, in case you are describing the task improperly?
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    I suspect that the OP cut off the thread on the brass nipple.
    If that's the case, unscrew the brass nipple and replace it with a new one.
    If thatis case, then it was a "do something even if it is wrong" action/reaction.
    Oct 2013
    Norwood, MA
    Thanks guys. I'll just spin on a new top as Terry suggested.
    I am actually just in the planning stages of a small kitchen renno and the 1/2" cold and hot water pipe under the sink is brass so I was just wondering if I could just cut the pipe back with a Sawsall and get new shutoffs with 1/2" compression fitting connections to be used on the brass pipe. I know enough about plumbing to be dangerous but everything in my house is so different from modern construction standards that I always make sure I come here before putting saw to pipe!
    What is the OD of the brass pipe? The stuff is pretty stiff, so a compression fitting probably wouldn't seal, even if the size was okay.
    FWIW, in MA, doing ANY plumbing without a license and a building permit can get you into hot water, so beware.
  1. Real Time Help: Pipe Compound with Compression Fittings
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-01-2010, 06:11 AM
  2. Installing compression fittings for PE gas pipe
    By FredC in forum HVAC Heating & Cooling
    Last Post: 11-18-2007, 11:22 AM
  3. compression fittings
    By dmetz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2007, 12:21 PM
  4. Compression fittings
    By Luken8r in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2006, 08:54 PM
  5. Compression fittings for PEX
    By themax3000 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2004, 08:29 AM
