Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 75 of 174
Thread: Volts leaking to ground rod
  1. #61
    Mar 2011
    Houston, TX
    Don, you have to be really fast. The polarity changes 60 times a second. Well... in some parts of the World at least. Not sure about in your alternate reality World.
    I guess I need to get a faster meter.
    In my alternate reality World we would use a O-Scope.
    Have Fun.
  2. #62
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Quote Originally Posted by Reach4 View Post
    When you measure voltage, it is with respect to a potential somewhere. If we are measuring with respect to the grounded center tap, the two hots are indeed 180 degrees out of phase with each other. Measuring WRT the grounded center tap is a most reasonable reference point.
    Quote Originally Posted by jwelectric View Post
    Pray tell us all just how the sine wave some how splits and inverts itself in a winding, it can't. There is no way possible that the winding can have a positive on both ends at the same time. Ever put batteries in a flashlight with one turned the wrong way? Didn't work did it? The same thing would happen if the winding some way ended up with a + at both ends
    JW, are you agreeing or disagreeing with what Reach4 is saying? I can't tell
  3. #63
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    Transformers work using AC not DC. You will need to view the sine waves with an oscilloscope to see the changes.
  4. #64
    Mar 2011
    Houston, TX
    Quote Originally Posted by ankhseeker View Post
    I figured I could just add a Rectumfier.
  5. #65
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by ActionDave View Post
    This would not be unusual given the nature of our power grid.
    I cannot say that the power guy was hysterical about it.
  6. #66
    Mar 2011
    Houston, TX
    Quote Originally Posted by Homeownerinburb View Post
    Did anyone take Ground rod resistance measurements ?
  7. #67
    Jun 2007
    North Carolina
    Quote Originally Posted by bluebinky View Post
    If you do away with the neutral then the secondary of the transformer would look just like the primary, one winding. When the positive arc in the sine wave enters the winding the winding becomes a magnet With a north and south pole as the sine wave returns to zero and enters the negative part if the sine wave the north and south of that electro magnet inverts. This happens 60 times a second which causes the winding of the secondary to do the very same thing. The center taps in no way changes this action taking place within the transformer.
    Take two volt and half cells and connect them in series and spin it around at 60 revolutions per second letting the ends rub against two slip rings and you will have three volts AC at 60 Hz. Hold then in place and it will be three volts DC. Connect a three volt light to these two batteries connected in series and it will burn. Connect a 240 volt appliance across the secondary of the transformer and it will work.
    With this three volt bulb burning a center tap of these two batteries and two 1.5 volt light bulbs can burn with one on one cell and the other on the other cell. All three are burning at one time.
    Install a center tap on that secondary winding and two 120 volt appliances can be connect with one on one end and the other on the other end at the very same time the 240 volt appliance is in operation.
    In order to have electrons flow there has to be a difference in potential or is you please a positive and a negative. If the two 120 volt sine waves were 180 degrees out of phase with each other this would mean that both ends of the winding would have to be positive at the same time and the center tap negative which would change 60 times a second. Also if they are 180 degrees out of phase the 240 volt appliance would not work.
    Connect the scope channel A to one end of the secondary and the ground to the other end of the winding you would see one sine wave of about 340 volts peak or 240 volts RMS. Now move the ground to the center tap and a sine wave of only half of the winding or 120 volts RMS. When channel B is connected to the other end we get to see both ends of the winding at the same time, channel A in positive and channel B is negative which is in sync with each other not 180 degrees out of phase.
    Using vector math we add the two together to come up with the single phase winding of the secondary. From the 120 volt reverence at both ends we have 240 volts. 120 from neutral to one end and 120 from neutral to the other end, is vector not degree of sine wave. We also use vector math when adding the two batteries, from the center tap to one end is 1.5 volts and from center to the other end we have 1.5 volts. This is the same as with the AC with the exception of the oscillation which AC has, or in other words while one end is positive the other end is negative.
  8. #68
    Aug 2011
    Santa Clara, CA
    JW, very good explanation which makes it clear you have perfect understanding of this subject. (not that any one ever doubted)
    ... Connect the scope channel A to one end of the secondary and the ground to the other end of the winding you would see one sine wave of about 340 volts peak or 240 volts RMS. Now move the ground to the center tap and a sine wave of only half of the winding or 120 volts RMS. When channel B is connected to the other end we get to see both ends of the winding at the same time, channel A in positive and channel B is negative which is in sync with each other not 180 degrees out of phase. ...
    However, (even though we're talking about a single-phase system) the correct terminology is that both hot legs are 180 degrees out of phase with respect to the neutral.
  9. #69
    Mar 2011
    Long Island, NY
    Hey! I resemble that remark!
  10. #70
    Jan 2012
    Los Angeles, CA USA
    Honestly, no, I don't own the gear. It is a few hundred dollars and I am inclined to assume that when I have a rod and copper pipe running horizontally for about 25', I should be good to go.
    Two rods plus the copper pipe would certainly get the job done, certainly. But that is not what we have on hand.
  11. #71
    Jan 2012
    Los Angeles, CA USA
    Why do I get these duplicate posts?
  12. #72
    DIY Senior Member Reach4's Avatar
    Sep 2013
    I
    Here is a picture of an oscilloscope with channel A being 180 degrees out of phase with channel B.
  13. #73
    Jan 2012
    Los Angeles, CA USA
    I cannot say that such an experiment has occurred to me, but it makes perfect sense.
    Kind of off point, mind you....
  14. #74
    Mar 2011
    Houston, TX
    When you get the message "Do you want to leave this page" after clicking Post Reply Click No, do not click Post Reply again.
    That should put your post on the server.
    Then close the page, you may get "Do you want to leave this page" again, Click Yes.
    It works something like that but is hard for me to splain.
    Good Luck.
  15. #75
    Jun 2007
    North Carolina
    No they are not 180 degrees out of phase they are referenced from a mid point. There is no way they could be 180 degrees out of phase with each other as there is only one winding that has a center tap unless there has been something new invented that will somehow let one winding be 180 degrees away from itself.
    What the scope is showing is a vector that is referenced from half way through a 240 bolt winding. As can be clearly seen is that while channel A is positive channel B is negative which means they are in phase not 180 degrees out of phase.
    In order to be 180 degrees out of phase then both ends would have the same polarity.
    Ever hear the old saying to believe nothing you hear and only half of what you see? Well that applies here until you take a course in vector math.
  1. Refrigerator is Hot - 120 Volts at Handle
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 02-11-2012, 06:38 AM
  2. 115 volts or 220 volts to well pump
    By JoeBarth in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-21-2008, 06:00 AM
  3. What's the difference between 240 volts and 220 volts?
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2008, 05:52 PM
  4. 14.4 volts vs 18 volt for homeowner
    By ctkeebler in forum Remodel Forum & Blog
    Last Post: 04-22-2008, 04:55 AM
  5. Please Help! Ground water leaking into heating ducts
    By tjwilson99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 04:53 AM
