Page 1 of 12 1234567891011 ... LastLast
Results 1 to 15 of 174
Thread: Volts leaking to ground rod
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default Volts leaking to ground rod
    Got a call to investigate an arc of electricity where grounding conductor to water supply coming into house was interrupted. Apparently there is a ground rod as well.
    I want to guess that some large item is leaking volts into the ground loop.
    If I find an electric stove, that is my first suspect.
    Any thoughts? I'll be looking at it first thing tomorrow.
    Feb 2011
    NW Ontario, Canada
    I would suspect a bad neutral. I had a case once with an open neutral where there was so much current going to the water supply that it warmed the water.
    Jan 2012
    Los Angeles, CA USA
    You mean to say at the panel or the top of the pole.
    Yes, I will certainly be poking around the panel looking for 120 v to both legs. If one of them is more than two or three volts off the other, I get suspicious.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Quote Originally Posted by Homeownerinburb View Post
    I agree with that Canadian up there, bad neutral. It could be at the service, at the pole, could even be a different house and now your customer's water pipe has become that neighbour’s neutral.
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by ActionDave View Post
    And THIS is where troubleshooting becomes a bitch!
    Jan 2012
    Los Angeles, CA USA
    What tests do you recommend?
    I have no problem calling it a bad neutral when one leg is 100v and the other is 140v, but one needs to be pretty dull witted to not see that.
    What if the voltage leaking out is on the order of 30v?
    Feb 2009
    Colorado
    Likely the same as you. At the service panel- Phase to phase, phase to neutral, phase to earth conductor; turn the main off and look for changes. You need at least 15V difference phase to neutral before you can rule out just plain old voltage drop from the POCO IMO.
    If you have a analogue meter check or a low Z on your digital check voltage between the ground rod and the neutral. Should not be very much volts.
    Put an ammeter around GEC. Turn off the main. Do the same at neighbour's house.
    Go out and look at the pole. If you talk to the POCO try and find somebody that has some service and trouble shooting experience on their end too.
    Jan 2012
    Los Angeles, CA USA
    All good stuff except I don't expect to be poking around in the neighbor's panel.
    I do expect to be calling the power company, very likely. They are very responsive here.
    Mar 2011
    Houston, TX
    If the neighbors are on a different transformer, I see no need to bother them.
    If you measure any current flowing on the Ground Rod conductor or water pipe ground, You should call the Power Company. If you do not have the proper tools, You should call the Power Company.
    You should not disconnect or mess with anyting that is arcing or throwing sparks, unless you have a Electrical license.
    A shorted element should pop a breaker if everything is wired and sized properly.
    Good Luck.
    quote; could even be a different house and now your customer's water pipe has become that neighbour’s neutral.
    That would be such a "stretch" that I would not even consider it. Possibly an electric water heater with a bad element, or as stated a failed neutral from the power company. I once disconnected an electric water heater and when I separated the union I had an arc. EVERYTHING in the house which was turned on immediately burned out when they were hit with 240 volts. I had to carry the huge console TV outside because it was smoking. The neutral had failed, and they connected to the ground rod with a piece of BX metal cover which had rusted away so the entire neutral "duty" was being done by the water system and since they had made the ground connection to the hot water, the current was going through the water heater which caused it to start leaking. Separating the union "undid" the whole process. Fortunately, I had had enough experience with poor wiring that I separated the union by hitting it with a wrench, rather than grabbing the two sides and pulling them apart, (which has killed many plumbers when they remove water meters without "jumpers" and some variation of this is occurring).
    Sep 2013
    Call the power company.
    For troubleshooting mainly for curiosity, get a clamp-around ammeter. Measure the current through that ground wire. Kill power at the main breaker. Does that current largely remain? If the current remains, that would show that the neutral conductor from the transformer is there, but if the current is significant, their grounding at the pole is not adequate. I don't know where I would draw the line of being adequate.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Reach4 View Post
    Just my thought, If a person does not have a clamp-around ammeter, They do not need to be working on a electrical job.
    I could be wrong.
    Jan 2012
    Los Angeles, CA USA
    All good stuff, guys.
    Not likely an electric water heater. Gas appliances are very common around here. There are some electric stoves, although I have no idea why.
    Yes, the amp flow test is on my list.
    Jan 2012
    Los Angeles, CA USA
    This particular utility grounds all of its transformers, so if I do find current in that test, then they will certainly be out like a flash to check it out.
    Mar 2011
    Long Island, NY
    I could be wrong.
    I have 2 Amprobes and a Bell current gun, so does that mean I am qualified? I have no plasma suit, so I am definitely not.
  1. Refrigerator is Hot - 120 Volts at Handle
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 02-11-2012, 06:38 AM
  2. 115 volts or 220 volts to well pump
    By JoeBarth in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-21-2008, 06:00 AM
  3. What's the difference between 240 volts and 220 volts?
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 08-16-2008, 05:52 PM
  4. 14.4 volts vs 18 volt for homeowner
    By ctkeebler in forum Remodel Forum & Blog
    Last Post: 04-22-2008, 04:55 AM
  5. Please Help! Ground water leaking into heating ducts
    By tjwilson99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 04:53 AM
