Safety of silicone in faucet fittings?
Tbbarch
Virginia
I have done a repair on a swiveling kitchen faucet.
The failure was in the O-rings around the swiveling center supply post.
The O-rings are lubricated and sealed(?) with silicone that came with the O-rings.
I find it disturbing that drinking water is flowing over silicone.
Has anyone back checked "plumbing" silicone and how it was validated to be safe?
Are there any chemist out there who are familiar with silicone variants and the reactions with treated water?
Thank you
DonL
Houston, TX
Should be no problem.
They use food grade silicone for Ice Maker trays.
And they put it in Boobs.
Have Fun.
Ankhseeker
San Pablo, California
Food grade silicone is also found in my draft beer system tap. No bad flavors from it. If the FDA didn't approve it, hopefully they wouldn't use it.
How much of the lube is actually in contact with the water you drink, anyway. You are being paranoid, or you live in California. As an aside, I don't lubricate my "O" rings.
Tbbarch
Virginia
The silicone needs to be put on heavy so that the faucet swivels.
It is what seals above and below the chamber that feeds the spout.
I take it there is no bad news anyone has heard.
Silicone is produced in all sorts of variations...a quality plumber's silicon grease is non-toxic.
Alaska or South Africa, huh? That means I either have to freeze my butt off or get eaten by a lion or a great white. No thanks. One of the articles mentions a Lockheed Electra. My daughter and I rode in an Electra from O'Hare to Benton Harbor. Since it was just a short hop the pilot stayed low. My daughter was terrified. Between the noise and vibration, (it was her first prop driver plane ride), then seeing the waters of Lake Michigan "right below the plane" she was sure we were all going to die.
JerryR
Active Member
Florida
Sorry for the thread creek.
I got to ride jump seat in an Electra from Griffiss AFB, NY to Tinker AFB, Oklahoma back in 1969. I was bringing some secret equipment to the depot for repair.
After getting out of the USAF I got my pilot license and have since logged over 3,000 hours as Pilot in Command, almost all propeller driven aircraft. Great hobby.
JR
